Insignia NS-F12R6-SS Upper Oscillation Gear Replacement
  1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: step 1, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: step 1, image 2 of 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 2, image 1 of 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 3, image 1 of 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Fan Blade: step 4, image 1 of 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 5, image 1 of 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Back Cage: step 6, image 1 of 1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 7, image 1 of 1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: step 8, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: step 8, image 2 of 2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 9, image 1 of 1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Motor Housing: step 10, image 1 of 1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 11, image 1 of 1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 12, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 12, image 2 of 2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 13, image 1 of 1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 14, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 14, image 2 of 2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 15, image 1 of 1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 16, image 1 of 1
    • Remove the small piece of paper hanging on the power button.
  17. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: step 17, image 1 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: step 17, image 2 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: step 17, image 3 of 3
    • Using a Phillips #3 screwdriver, unscrew and remove the 7 mm long bolt and small washer fastening the yellow and green wire to the motor housing support.
  18. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 18, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 18, image 2 of 2
    • Using a Phillips #3 screwdriver unscrew the 13 mm long screw fastening the motor housing support to the oscillation gear box.
  19. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 19, image 1 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 19, image 2 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 19, image 3 of 3
    • Using a Phillips #3 screwdriver, unscrew the three 13 mm long screws fastening the grey plate to the top of the oscillation gear box.
    • Remove the grey cap covering the oscillation gear box.
  20. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 20, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 20, image 2 of 2
    • Remove the upper oscillation gear.
Hank
1,142 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 12
All Time: 597
