Insignia NS-HTMC01-B Power Cord Replacement
  1. Insignia NS-HTMC01-B Power Cord Replacement, Front Case: step 1, image 1 of 3 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: step 1, image 2 of 3 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: step 1, image 3 of 3
    • Flip the device over so the back panel faces up.
    • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
    • You may want to use a flashlight during this step, as the screws are hard to see.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
  2. Insignia NS-HTMC01-B Power Cord Replacement: step 2, image 1 of 1
    • Take the screws out and set them aside.
    • Be sure to set them somewhere flat, so they don't roll away.
    • Gently pull the front panel and back panel apart to open the device.
  3. Insignia NS-HTMC01-B Power Cord Replacement, Power Cord: step 3, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two 1.7mm screws from the white triangular piece covering the power cord.
  4. Insignia NS-HTMC01-B Power Cord Replacement: step 4, image 1 of 1
    • Disconnect all of the blue wires. There should be 3 separate blue-wire connections.
  5. Insignia NS-HTMC01-B Power Cord Replacement: step 5, image 1 of 1
    • Disconnect the second black wire from the rectangular piece above the Tip-Over Safety Switch.
    • Remove power cord.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 203
