Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement
  1. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the rubber sleeve.
  2. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 2, image 1 of 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 2, image 2 of 2
    • Use the specified screwdriver to unscrew the ten screws on the back cover.
  3. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 3, image 1 of 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 3, image 2 of 2
    • Remove the back cover. Be careful to not lose any of the screws because they are extremely small and can be easily lost.
  4. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 4, image 1 of 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 4, image 2 of 2
    • The battery will be attached to the back cover with sticky tape. Unplug the wires connecting the battery to the speaker.
    • Using one of the four blue opening tools, pry the battery off of the back cover.
  5. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 6, image 1 of 1
    • Stick the new battery to the back cover using sticky tape.
  6. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 7, image 1 of 1
    • Connect the wire from the new battery to the bluetooth speaker.
  7. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 8, image 1 of 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 8, image 2 of 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: step 8, image 3 of 3
    • Place cover back on and using the iFixit screwdriver PH000, screw the ten screws back onto the back cover.
Erin Steele
649 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 306
