Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement
  1. Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement, Bluetooth Button: step 1, image 1 of 1
    • Remove the rubber sleeve.
  2. Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 2, image 1 of 2 Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 2, image 2 of 2
    • Remove 4 screws from the green, plastic button cover.
  3. Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 3, image 1 of 2 Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 3, image 2 of 2
    • After successfully removing the plastic cover, use a sauter against the bluetooth button. The heat will make the removal of the button easy.
    • Place the new bluetooth button in the place of the old bluetooth button and mend the button into place using heat.
  4. Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 5, image 1 of 3 Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 5, image 2 of 3 Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 5, image 3 of 3
    • Screw the 4 screws of the plastic button cover back onto the device.
  5. Insignia NS-SPBTBRICK-CM Bluetooth Button Replacement: step 6, image 1 of 1
    • Put the plastic sleeve back onto the speaker.
Erin Steele
649 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 65
