Insignia NS-SPBTBRICK-CM Speaker Replacement
  1. Insignia NS-SPBTBRICK-CM Speaker Replacement, Battery: step 1, image 1 of 2 Insignia NS-SPBTBRICK-CM Speaker Replacement, Battery: step 1, image 2 of 2
    • Run your hand around the device where the sleeve connects, lifting lightly up until the edges detach from the device case.
  2. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 2, image 1 of 2 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 2, image 2 of 2
    • Turn the device around and gently push the speaker through until it separates from the sleeve.
  3. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 3, image 1 of 2 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 3, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the the ten 5.1mm screws that hold down the battery panel on the bottom of the speaker unit.
  4. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 4, image 1 of 3 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 4, image 2 of 3 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 4, image 3 of 3
    • Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel.
  5. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 5, image 1 of 2 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, carefully detach the battery wire from the circuit board and lift out the panel with the attached battery.
  6. Insignia NS-SPBTBRICK-CM Speaker Replacement, Speaker: step 6, image 1 of 3 Insignia NS-SPBTBRICK-CM Speaker Replacement, Speaker: step 6, image 2 of 3 Insignia NS-SPBTBRICK-CM Speaker Replacement, Speaker: step 6, image 3 of 3
    • Using hands or a spudger, pry the front side of the plastic shielding (side opposite of power, control, and auxiliary port cover) from the device.
  7. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 7, image 1 of 2 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 7, image 2 of 2
    • Lift the front plastic shielding from the device.
  8. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 8, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the eight 10mm screws on the revealed front panel.
  9. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 9, image 1 of 2 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 9, image 2 of 2
    • Turn the device around and remove the rear panel from the device to reveal the device’s speaker units.
  10. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 10, image 1 of 3 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 10, image 2 of 3 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 10, image 3 of 3
    Buy
    • Remove the speaker brackets of the speaker to be replaced by unscrewing the three 7.5mm screws holding them in place with the Phillips #1 screwdriver.
    • If the brackets do not come out with the screws you may need to pull them out with tweezers.
  11. Insignia NS-SPBTBRICK-CM Speaker Replacement: step 11, image 1 of 2 Insignia NS-SPBTBRICK-CM Speaker Replacement: step 11, image 2 of 2
    • Using tweezers, detach the cord connecting the speaker to the device and lift out the speaker.
If desired, repeat steps 10 and 11 to replace the other speaker within the device. Follow the steps of this guide and the battery replacement guide in reverse order to reassemble the device.
ETHAN BRUNHOFER
158 Reputation
1 Guide authored
IUPUI, Team S2-G6, Harley Spring 2018 Member of IUPUI, Team S2-G6, Harley Spring 2018
IUPUI-HARLEY-S18S2G6
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 400
