Inspiron 17 5758 Hard Drive Replacement
  1. Inspiron 17 5758 Hard Drive Replacement, Remove battery: step 1, image 1 of 1
    • Flip the laptop over, battery facing you. Move the latch to the right, and grab the battery as it comes up.
  2. Inspiron 17 5758 Hard Drive Replacement, Remove hard drive cover: step 2, image 1 of 1
    • Remove the two Philips screws securing the hard drive cover.
    • Use a spudger in the provided hole to pry the cover upwards.
  3. Inspiron 17 5758 Hard Drive Replacement, Remove hard drive caddy: step 3, image 1 of 1
    • Remove the four Philips screws securing the hard drive caddy.
    • Remove the four screws from the hard drive caddy, and take the SATA connector off. You're done!
Joseph Sctbunio
7,527 Reputation
42 Guides authored
One Comment
I found it very straightforward to purchase a Kingston KC600 SSD drive, which includes an external caddy, then use the free Aomei cloning software to clone the existing drive, then follow this article to open up the Inspiron, remove the SATA drive and install the KC600 drive instead. Thanks! It had become unbearable slow running Windows 10 but now has another lease of life.
Imogen - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 818
