Inspiron 7359 2-in-1 Battery Replacement
  1. Inspiron 7359 2-in-1 Battery Replacement, Disassembling the Inspiron 7359 2-in-1: step 1, image 1 of 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Battery Replacement: step 2, image 1 of 2 Inspiron 7359 2-in-1 Battery Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Battery Replacement: step 3, image 1 of 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Battery Replacement: step 4, image 1 of 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Battery Replacement, Battery: step 5, image 1 of 1
    • Unscrew two 8mm screws with a Phillips #0 screwdriver.
    • Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Make sure to keep all screws together and label where you unscrewed them from.
  6. Inspiron 7359 2-in-1 Battery Replacement: step 6, image 1 of 1
    • To remove the old battery, lift from the bottom and pull the battery towards you.
To reassemble your device, follow these instructions in reverse order using a new battery.
2 other people completed this guide.
Alfredo Acosta
141 Reputation
1 Guide authored
Gateway, Team S1-G3, Saknee Fall 2019 Member of Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 122
