Inspiron 7359 2-in-1 WiFi Card Replacement
  1. Inspiron 7359 2-in-1 WiFi Card Replacement, Disassembling the Inspiron 7359 2-in-1: step 1, image 1 of 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 WiFi Card Replacement: step 2, image 1 of 2 Inspiron 7359 2-in-1 WiFi Card Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 WiFi Card Replacement: step 3, image 1 of 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 WiFi Card Replacement: step 4, image 1 of 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: step 5, image 1 of 2 Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: step 5, image 2 of 2
    • Use the spudger tool to remove the two antenna cables.
    • Remove the black screw.
    • Slightly pull up the end and remove the WiFi card. Be careful not to damage the internal adapter.
Annberlisa Ronald
109 Reputation
1 Guide authored
Gateway, Team S1-G3, Saknee Fall 2019 Member of Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 169
