Install an Extension Cord Female Plug
  1. Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: step 1, image 1 of 3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: step 1, image 2 of 3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: step 1, image 3 of 3
    • Install an Extension Cord Female Plug is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut from the middle and around the cable.
  2. Install an Extension Cord Female Plug: step 2, image 1 of 3 Install an Extension Cord Female Plug: step 2, image 2 of 3 Install an Extension Cord Female Plug: step 2, image 3 of 3
    • Use wire strippers to remove about 2 cm from the inner wires
  3. Install an Extension Cord Female Plug: step 3, image 1 of 2 Install an Extension Cord Female Plug: step 3, image 2 of 2
    • Make sure you put the bottom cover of the female plug.
  4. Install an Extension Cord Female Plug: step 4, image 1 of 3 Install an Extension Cord Female Plug: step 4, image 2 of 3 Install an Extension Cord Female Plug: step 4, image 3 of 3
    • The green screw is for the (green wire), the gold screw is for the (black wire), and the silver screw is for the (white wire).
    • For green wire.
    • For black wire
    • For white wire.
    • Now when you have each wire inside the hole you tighten the three screws.
  5. Install an Extension Cord Female Plug: step 5, image 1 of 3 Install an Extension Cord Female Plug: step 5, image 2 of 3 Install an Extension Cord Female Plug: step 5, image 3 of 3
    • Electrical tape is optional.
    • Need to make sure both of the parts are lined up in the same directions.
    • Push both parts together and you would see the screws pop up.
  6. Install an Extension Cord Female Plug: step 6, image 1 of 3 Install an Extension Cord Female Plug: step 6, image 2 of 3 Install an Extension Cord Female Plug: step 6, image 3 of 3
    • Tightening the top three screws.
    • Also, need to tighten the two bottom screws.
    • Make sure you have one or two fingers in the back of the two screws so they pop up.
  7. Install an Extension Cord Female Plug: step 7, image 1 of 1
    • Test out.
2 other people completed this guide.
Steven Quintero
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 110
All Time: 1,484
