Install the Battery on bObi Pet
Chelsea
Chelsea and one other contributor
Last updated on August 31, 2016
No estimate
Very easy
Community-Contributed Guide
Introduction
Go to step 1
Follow these few steps to easily set up your new bObi Pet's battery or install a new one.
For a video tutorial, go to: https://www.youtube.com/watch?v=qpfeK7GP...
iFixit earns commission when you buy through these links.
  1. Install the Battery on bObi Pet, Turn bObi Pet Off: step 1, image 1 of 2 Install the Battery on bObi Pet, Turn bObi Pet Off: step 1, image 2 of 2
    • Make sure bObi Pet's power switch is turned OFF.
    • Then, flip bObi Pet over onto a flat surface, so the wheels point up.
  2. Install the Battery on bObi Pet, Open the Battery Compartment: step 2, image 1 of 3 Install the Battery on bObi Pet, Open the Battery Compartment: step 2, image 2 of 3 Install the Battery on bObi Pet, Open the Battery Compartment: step 2, image 3 of 3
    • Remove the two screws holding her battery cover in place.
    • Remove the battery cover. Keep the cover and screws close by for the next step.
  3. Install the Battery on bObi Pet, Plug in the New Battery: step 3, image 1 of 3 Install the Battery on bObi Pet, Plug in the New Battery: step 3, image 2 of 3 Install the Battery on bObi Pet, Plug in the New Battery: step 3, image 3 of 3
    • Plug the new battery in at the circuit junction.
    • Tuck the wire into the side of the compartment.
    • Ensure the wires are not in the way, then, slide the battery straight down.
  4. Install the Battery on bObi Pet, Replace the Battery Cover: step 4, image 1 of 3 Install the Battery on bObi Pet, Replace the Battery Cover: step 4, image 2 of 3 Install the Battery on bObi Pet, Replace the Battery Cover: step 4, image 3 of 3
    • Replace the battery cover so that it lies flat.
    • Reinstall the 2 screws to finish the installation process.
After finishing the battery installation correctly, turn bObi Pet's side power switch to ON and your robotic vacuum should be ready to work.
Chelsea
2,278 Reputation
31 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 179
