Installation/Removal of the WIC/HWIC card
Featured Document
  1. Installation/Removal of the WIC/HWIC card, Turn the equipment off: step 1, image 1 of 1
    • In order to install or remove a card the equipment should be turned off.
  2. Installation/Removal of the WIC/HWIC card, Remove the port covers on the EHWIC: step 2, image 1 of 3 Installation/Removal of the WIC/HWIC card, Remove the port covers on the EHWIC: step 2, image 2 of 3 Installation/Removal of the WIC/HWIC card, Remove the port covers on the EHWIC: step 2, image 3 of 3
    • Loosen the cards' screws.
    • Do not remove them completely. Once they are loose the spring will push the screw outwards.
    • To remove, pull on the card.
    • It is recommended that you clean the card of dust.
  3. Installation/Removal of the WIC/HWIC card, Insert the card: step 3, image 1 of 2 Installation/Removal of the WIC/HWIC card, Insert the card: step 3, image 2 of 2
    • Insert the card or install the protective router cover to avoid dust accumulation.
To re-assemble your device, follow these instructions in reverse.
Special thanks to these translators:
es en
100%
WhoDat? is helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Eneider Colina
2,370 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 40
All Time: 911
