Installing Sewing Machine Bobbin
  1. Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: step 1, image 1 of 2 Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: step 1, image 2 of 2
    • Use your finger to open the bobbin door below the presser foot.
  2. Installing Sewing Machine Bobbin: step 2, image 1 of 2 Installing Sewing Machine Bobbin: step 2, image 2 of 2
    • Align the hole in the bobbin spindle over the peg in the bobbin case.
    • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
    • Take the loose thread end and slide it through the slit on the side of the bobbin case.
  3. Installing Sewing Machine Bobbin: step 3, image 1 of 2 Installing Sewing Machine Bobbin: step 3, image 2 of 2
    • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
  4. Installing Sewing Machine Bobbin: step 4, image 1 of 2 Installing Sewing Machine Bobbin: step 4, image 2 of 2
    • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
    • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
  5. Installing Sewing Machine Bobbin: step 5, image 1 of 2 Installing Sewing Machine Bobbin: step 5, image 2 of 2
    • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
    • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
    • Release the bobbin case.
  6. Installing Sewing Machine Bobbin: step 6, image 1 of 2 Installing Sewing Machine Bobbin: step 6, image 2 of 2
    • Close the door on the compartment below the presser foot.
Finish Line
7 other people completed this guide.
Brittany McCrigler
90,514 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,806 Guides authored
1 Guide Comment
Love it! Thank you for posting this as my wife has had to fix things on her sewing machine and it's good to have a reference other than Youtube where you can sit down and read it and make adjustments accordingly!
Alex - Reply
Past 24 Hours: 10
Past 7 Days: 69
Past 30 Days: 293
All Time: 57,782
