Instant Pot IP-DUO80 V2 LED Display Replacement
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: step 1, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: step 1, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: step 1, image 3 of 3
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: step 2, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 2, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 2, image 3 of 3
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: step 3, image 1 of 2 Instant Pot IP-DUO80 V2 LED Display Replacement: step 3, image 2 of 2
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: step 4, image 1 of 2 Instant Pot IP-DUO80 V2 LED Display Replacement: step 4, image 2 of 2
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: step 5, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 5, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 5, image 3 of 3
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: step 6, image 1 of 1
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: step 7, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 7, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 7, image 3 of 3
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
6 other people completed this guide.
Kayla Meacham
634 Reputation
5 Guides authored
Cal Poly, Team S18-G2, Livingston Winter 2018 Member of Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 Members
10 Guides authored
2 Comments
Where can I get the replacement for the display?
Starfish Doodle - Reply
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 49
All Time: 6,869
