Instant Pot Smart-60 Disassembly
  1. Instant Pot Smart-60 Disassembly, Bottom access plate screw: step 1, image 1 of 3 Instant Pot Smart-60 Disassembly, Bottom access plate screw: step 1, image 2 of 3 Instant Pot Smart-60 Disassembly, Bottom access plate screw: step 1, image 3 of 3
    • Insert wisdom here.
  2. Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: step 2, image 1 of 3 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: step 2, image 2 of 3 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: step 2, image 3 of 3
    • Remove 3x bolts
  3. Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: step 3, image 1 of 3 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: step 3, image 2 of 3 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: step 3, image 3 of 3
  4. Instant Pot Smart-60 Disassembly, Circuit board 1: step 4, image 1 of 3 Instant Pot Smart-60 Disassembly, Circuit board 1: step 4, image 2 of 3 Instant Pot Smart-60 Disassembly, Circuit board 1: step 4, image 3 of 3
    • Black molex connector on top right must come out to remove the outer shell.
    • Red wire spring clips with blue translucent covers I was unable to remove safely, I suggest removing other ends of those wires if you need to remove the heating element plate.
  5. Instant Pot Smart-60 Disassembly, Battery and front panel wires: step 5, image 1 of 3 Instant Pot Smart-60 Disassembly, Battery and front panel wires: step 5, image 2 of 3 Instant Pot Smart-60 Disassembly, Battery and front panel wires: step 5, image 3 of 3
    • I needed small needle nose pliers to pinch and remove wide front panel connector.
  6. Instant Pot Smart-60 Disassembly, Outer shell ground wire: step 6, image 1 of 3 Instant Pot Smart-60 Disassembly, Outer shell ground wire: step 6, image 2 of 3 Instant Pot Smart-60 Disassembly, Outer shell ground wire: step 6, image 3 of 3
  7. Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: step 7, image 1 of 3 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: step 7, image 2 of 3 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: step 7, image 3 of 3
  8. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: step 8, image 1 of 3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: step 8, image 2 of 3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: step 8, image 3 of 3
    • I'm skipping removing heating element and nearby sensors, it's similar to other models. Search for Instant Pot repair videos for instructions.
  9. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: step 9, image 1 of 3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: step 9, image 2 of 3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: step 9, image 3 of 3
  10. Instant Pot Smart-60 Disassembly, Outer shell re-assembly: step 10, image 1 of 2 Instant Pot Smart-60 Disassembly, Outer shell re-assembly: step 10, image 2 of 2
    • Pull lid sensor wire up, re-tape to inside of outer shell.
    • Battery replacement, you should remove the screw and pull the mini circuit board holding the battery before attempting to swap batteries.
8 other people completed this guide.
Zen1
392 Reputation
1 Guide authored
4 Guide Comments
If the outer shell is dented but panel is functioning is it safe to operate the instant pot? looks like it moved a bit in the box in shipment, no visible damage to the pot just the to the aluminum shell
Jeff Medlin - Reply Share
Mine is dented and it should be totally fine. As you said, the pressure vessel is separate from the outer shell, so there are no safety concerns. Just asthetic. I wish there wasn't this gap of air between the pressure vessel and the outer shell, or, I wish the shell was a bit more durable as it's VERY easily dented.
Kuake Ye - Reply Share
What is the voltage of the component named ZNR091
Yanni Koulandris - Reply Share
I recently used and cleaned my instant pot. After cleaning I found a small spring in the sink. I am wondering if it came from the pot. I have looked at dozens of diagrams and do not see a spring. What are you opinions, safe to use, not safe. Any thoughts ?
Dave - Reply Share
Past 24 Hours: 5
Past 7 Days: 41
Past 30 Days: 145
All Time: 9,805
