Intel NUC8i7BEH Disassembly
  1. Intel NUC8i7BEH Disassembly, Turn NUC upside down: step 1, image 1 of 3 Intel NUC8i7BEH Disassembly, Turn NUC upside down: step 1, image 2 of 3 Intel NUC8i7BEH Disassembly, Turn NUC upside down: step 1, image 3 of 3
    • Place the NUC upside down and select a PH2 Phillips screw driver bit
  2. Intel NUC8i7BEH Disassembly, Unscrew lower lid: step 2, image 1 of 2 Intel NUC8i7BEH Disassembly, Unscrew lower lid: step 2, image 2 of 2
    • Start by using a Phillips head #2 screw driver to remove the lower screws on the lower case door.
    • These screws are held in with retainers, so they won't fall out when you flip the lid.
  3. Intel NUC8i7BEH Disassembly, Lid and HDD Bracket: step 3, image 1 of 3 Intel NUC8i7BEH Disassembly, Lid and HDD Bracket: step 3, image 2 of 3 Intel NUC8i7BEH Disassembly, Lid and HDD Bracket: step 3, image 3 of 3
    • Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay.
    • Carefully unplug the cables from the motherboard, and set the bracket aside.
    • In the last photo, the slot for a blade SSD is marked with a red arrow. This is where you would install the blade SSD, and use a screw to hold it in place.
  4. Intel NUC8i7BEH Disassembly, SSD removal: step 4, image 1 of 2 Intel NUC8i7BEH Disassembly, SSD removal: step 4, image 2 of 2
    • Change the screw driver bit to the PH1 one.
    • Unscrew the V-NAND SSD and carefully slide it out of its connector.
    • Previous step as video
  5. Intel NUC8i7BEH Disassembly, Motherboard Removal (Screw driver): step 6, image 1 of 1
    • Change the screw driver bit to PH1
  6. Intel NUC8i7BEH Disassembly, Motherboard Removal: step 7, image 1 of 3 Intel NUC8i7BEH Disassembly, Motherboard Removal: step 7, image 2 of 3 Intel NUC8i7BEH Disassembly, Motherboard Removal: step 7, image 3 of 3
    • Unscrew the screws marked in red circles
  7. Intel NUC8i7BEH Disassembly, Motherboard Removal, continued.: step 8, image 1 of 3 Intel NUC8i7BEH Disassembly, Motherboard Removal, continued.: step 8, image 2 of 3 Intel NUC8i7BEH Disassembly, Motherboard Removal, continued.: step 8, image 3 of 3
    • Remove the WiFi and Bluetooth antenna cables (be extremely careful when doing this otherwise you risk to rip the base contact terminal off the PCB)
    • Remove the stereo mic cable from the motherboard connector.
    • Pay attetion to the WiFi cable hidden under a black piece of tape
    • Disconnect mic cable
    • Remove padders from the sides
  8. Intel NUC8i7BEH Disassembly, Remove protection padding, continued: step 11, image 1 of 2 Intel NUC8i7BEH Disassembly, Remove protection padding, continued: step 11, image 2 of 2
    • Not all are necessary only the two depicted.
  9. Intel NUC8i7BEH Disassembly, Motherboard Removal, final step: step 12, image 1 of 3 Intel NUC8i7BEH Disassembly, Motherboard Removal, final step: step 12, image 2 of 3 Intel NUC8i7BEH Disassembly, Motherboard Removal, final step: step 12, image 3 of 3
    • Use a pry tool to lift the motherboard from the casing
    • Marked with red circles the dust signs evident on first sight
31 other people completed this guide.
Vladimir Knobel
2,746 Reputation
2 Guides authored
11 Comments
I’ve awarded the 30 points because these how to in steps are just great. One little critic, having read other stuff I understood the later models had greater risks of breaking things because of the more complicated wifi and mic cables, and these steps could have been better explained, like do the wifi cables plug in or slide off a splade like connection, and what can I use as a pry tool from around the house. These are the frightening steps to someone who has not done this unit before, while just about everything else isn’t much different to opening and taking parts out of a laptop.
Marlon Kirby - Reply
Thank You, I was having fan noise issues with my NUCi7BEH and was trying to figure out how to pop the MOBO from the case.
This guide was fantastic, loads of dust collected on the heat sink, clean air and it seems to be running great now.
Ave temp before this clean out was 65ºC but would spike from 90-100ºC under any load at all, even the VMs just spinning up.
Now after clean, all is good, temps idle sitting at around 35ºC now and under load about 70º C. Huge difference.
Big Thanks to Vladimir for making this wonderful guide.
Alan - Reply
Thanks, Vladimir Knobel, for putting together this excellent instruction with video and pictures. I used it to remove and replace my fan. I greatly appreciate it!!
Jeff Humpton - Reply
merci, ça m’a bien aidé et j’espère avoir résolu ce pb de ventirad, j’ai pu dépoussiérer. encore merci.
contactsebastien - Reply
thanks for all ! Experienced pb with my Intel® NUC Kit NUC8i5BEH : CMOS battery failed. Everything is ok now thank you for all the screens and videos very good tutorial to disassemble and check the problem
Regards Raph
Raph GLC - Reply
Past 24 Hours: 41
Past 7 Days: 260
Past 30 Days: 1,233
All Time: 47,856
