JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: step 1, image 1 of 1
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 2, image 1 of 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 2, image 2 of 2
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 3, image 1 of 1
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 4, image 1 of 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 4, image 2 of 2
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 5, image 1 of 1
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 6, image 1 of 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: step 6, image 2 of 2
    • Slide the ribbon gently out of the connector.
17 other people completed this guide.
John Reynolds
3,158 Reputation
4 Guides authored
UMass Dartmouth, Team 4-1, Catania Fall 2015 Member of UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Members
12 Guides authored
15 Comments
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - Reply
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - Reply
I think it is not normal, if you can find it please contact me! Thanks
I also need to replace my usb connector, has anyone found out where to get one?
Rick - Reply
need the micro-usb aswell
hellgrenmicke - Reply
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 74
All Time: 27,012
