JBL Charge 2 Plus Passive Radiators Replacement
  1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: step 1, image 1 of 2 JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: step 1, image 2 of 2
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 1 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 2 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 3 of 3
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Passive Radiators Replacement: step 3, image 1 of 2 JBL Charge 2 Plus Passive Radiators Replacement: step 3, image 2 of 2
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Passive Radiators Replacement: step 4, image 1 of 1
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 1 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 2 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 3 of 3
    • Repeat Step 2, 3 and 4 for the other passive radiator.
7 other people completed this guide.
John Reynolds
3,246 Reputation
4 Guides authored
UMass Dartmouth, Team 4-1, Catania Fall 2015 Member of UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Members
12 Guides authored
3 Comments
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
Jomon johny - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 13
All Time: 17,854
