JBL Charge 2 Speakers Replacement
  1. JBL Charge 2 Speakers Replacement, Battery: step 1, image 1 of 1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Speakers Replacement: step 2, image 1 of 2 JBL Charge 2 Speakers Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Speakers Replacement: step 3, image 1 of 2 JBL Charge 2 Speakers Replacement: step 3, image 2 of 2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Speakers Replacement: step 4, image 1 of 2 JBL Charge 2 Speakers Replacement: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Speakers Replacement: step 5, image 1 of 1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Speakers Replacement: step 6, image 1 of 3 JBL Charge 2 Speakers Replacement: step 6, image 2 of 3 JBL Charge 2 Speakers Replacement: step 6, image 3 of 3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Speakers Replacement, Speakers: step 7, image 1 of 1
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Speakers Replacement: step 8, image 1 of 1
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Speakers Replacement: step 9, image 1 of 1
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
2 other people completed this guide.
Mauzor Ilonzo
519 Reputation
3 Guides authored
USF Tampa, Team S2-G4, Passmore Fall 2017 Member of USF Tampa, Team S2-G4, Passmore Fall 2017
USFT-PASSMORE-F17S2G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 39
All Time: 4,913
