JBL Charge 3 Passive Radiators Replacement
  1. JBL Charge 3 Passive Radiators Replacement, Passive Radiators: step 1, image 1 of 3 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: step 1, image 2 of 3 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: step 1, image 3 of 3
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  2. JBL Charge 3 Passive Radiators Replacement: step 2, image 1 of 2 JBL Charge 3 Passive Radiators Replacement: step 2, image 2 of 2
    • Insert the plastic opening tools underneath both tabs.
  3. JBL Charge 3 Passive Radiators Replacement: step 3, image 1 of 1
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
  4. JBL Charge 3 Passive Radiators Replacement: step 4, image 1 of 2 JBL Charge 3 Passive Radiators Replacement: step 4, image 2 of 2
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
5 other people completed this guide.
Jack Ng
2,228 Reputation
4 Guides authored
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G6, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G6
4 Members
27 Guides authored
4 Comments
i have a different model of the charge 3 it doesnt have screws but its hard to take out
Water Bass Tester (Water BT) - Reply
mine has screws and was also hard to pull with one hand
Carbon cookie -
Ich finde den Passivenstrahler nicht als Ersatzteil im Internet. Kann wer da helfen?
Sebastix01 _ - Reply
I have two of the same without screws, the process is precisely the same. Just need to do it a little bit harder
Francisco Sarmento - Reply
Past 24 Hours: 0
Past 7 Days: 38
Past 30 Days: 108
All Time: 15,402
