JBL Charge 3 Speaker Replacement
  1. JBL Charge 3 Speaker Replacement, Front Cover: step 1, image 1 of 3 JBL Charge 3 Speaker Replacement, Front Cover: step 1, image 2 of 3 JBL Charge 3 Speaker Replacement, Front Cover: step 1, image 3 of 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Speaker Replacement: step 2, image 1 of 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. JBL Charge 3 Speaker Replacement, Speaker: step 3, image 1 of 2 JBL Charge 3 Speaker Replacement, Speaker: step 3, image 2 of 2
    • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
  4. JBL Charge 3 Speaker Replacement: step 4, image 1 of 1
    • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
  5. JBL Charge 3 Speaker Replacement: step 5, image 1 of 3 JBL Charge 3 Speaker Replacement: step 5, image 2 of 3 JBL Charge 3 Speaker Replacement: step 5, image 3 of 3
    • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
  6. JBL Charge 3 Speaker Replacement: step 6, image 1 of 1
    • Repeat the previous step for the second connector.
  7. JBL Charge 3 Speaker Replacement: step 7, image 1 of 2 JBL Charge 3 Speaker Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
  8. JBL Charge 3 Speaker Replacement: step 8, image 1 of 1
    • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
44 other people completed this guide.
Aidan Hays
3,936 Reputation
2 Guides authored
Cal Poly, Team S13-G1, White Fall 2018 Member of Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Members
26 Guides authored
31 Comments
Where I can buy the same jbl speaker ?
Ekinox - Reply
I need to replace my JBL charge 3 speaker
Lara Esther -
Where can buy the small speakers? Helpp
Luis Cilia - Reply
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - Reply
where can i buy the replacement speakers?
Yhamani Pangarungan - Reply
Past 24 Hours: 30
Past 7 Days: 201
Past 30 Days: 943
All Time: 90,702
