JBL Charge 4 Passive Bass Radiators Replacement
  1. JBL Charge 4 Passive Bass Radiators Replacement, Speaker Grill: step 1, image 1 of 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Passive Bass Radiators Replacement: step 2, image 1 of 2 JBL Charge 4 Passive Bass Radiators Replacement: step 2, image 2 of 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Passive Bass Radiators Replacement: step 3, image 1 of 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: step 4, image 1 of 2 JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: step 4, image 2 of 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Passive Bass Radiators Replacement: step 5, image 1 of 2 JBL Charge 4 Passive Bass Radiators Replacement: step 5, image 2 of 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
9 other people completed this guide.
Zachary Colwell
1,944 Reputation
5 Guides authored
Cal Poly, Team S1-G1, White Winter 2019 Member of Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Members
26 Guides authored
5 Comments
Exactly where are supposed to get parts for this, do you suppose !?
Yash Bhushan - Reply
It says it on the top of the introduction
Jacob Galeano Garcia -
Hi do you hany any suggestion on where to buy the passive radiators?
Epolu Isaac Tushabe - Reply
Were can i get the main cover from can you help please and the subwoofers
Nate Millette - Reply
Yo tengo la charge 4 y se me rompiĆ³ uno de los radiadores lo que yo quisiera saber si se pueden arreglar o lo tengo que cambiar por otro
Reynaldo Ronquillo - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 76
All Time: 7,035
