JBL Charge 5 Passive Bass Radiators Replacement
  1. JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: step 1, image 1 of 3 JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: step 1, image 2 of 3 JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: step 1, image 3 of 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Passive Bass Radiators Replacement: step 2, image 1 of 3 JBL Charge 5 Passive Bass Radiators Replacement: step 2, image 2 of 3 JBL Charge 5 Passive Bass Radiators Replacement: step 2, image 3 of 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Passive Bass Radiators Replacement: step 3, image 1 of 3 JBL Charge 5 Passive Bass Radiators Replacement: step 3, image 2 of 3 JBL Charge 5 Passive Bass Radiators Replacement: step 3, image 3 of 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: step 4, image 1 of 3 JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: step 4, image 2 of 3 JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: step 4, image 3 of 3
    • Using a spudger, pry the radiator off of the frame of the device.
    • Repeat on the other side if necessary.
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 303
