JBL Charge Button Membrane Replacement
  1. JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: step 1, image 1 of 3 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: step 1, image 2 of 3 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: step 1, image 3 of 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Button Membrane Replacement: step 2, image 1 of 2 JBL Charge Button Membrane Replacement: step 2, image 2 of 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Button Membrane Replacement: step 3, image 1 of 2 JBL Charge Button Membrane Replacement: step 3, image 2 of 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Button Membrane Replacement: step 4, image 1 of 2 JBL Charge Button Membrane Replacement: step 4, image 2 of 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Button Membrane Replacement: step 5, image 1 of 2 JBL Charge Button Membrane Replacement: step 5, image 2 of 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Button Membrane Replacement: step 6, image 1 of 2 JBL Charge Button Membrane Replacement: step 6, image 2 of 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Button Membrane Replacement: step 7, image 1 of 2 JBL Charge Button Membrane Replacement: step 7, image 2 of 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Button Membrane Replacement, Motherboard: step 8, image 1 of 1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Button Membrane Replacement: step 9, image 1 of 2 JBL Charge Button Membrane Replacement: step 9, image 2 of 2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Button Membrane Replacement: step 10, image 1 of 1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Button Membrane Replacement: step 11, image 1 of 2 JBL Charge Button Membrane Replacement: step 11, image 2 of 2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
  12. JBL Charge Button Membrane Replacement, Button Membrane: step 12, image 1 of 1
    • Locate the buttons on top of the device. Peel the white piece of tape located along the side of this button membrane.
  13. JBL Charge Button Membrane Replacement: step 13, image 1 of 1
    • Gently pull out the button membrane. You should not expect much resistance.
4 other people completed this guide.
Jake Bertholf
378 Reputation
2 Guides authored
Cal Poly, Team 12-1, Lancaster Spring 2015 Member of Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 Members
11 Guides authored
2 Guide Comments
conseguiste el boton de repuesto?
Mario A Vargas S - Reply
Por favor, disculpe mis errores:
"No puedo encontrar un nuevo reemplazo. Compra uno roto. Utilice el botón de la que se rompe."
Joe Durand -
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 44
All Time: 10,173
