JBL Charge Micro USB / Aux Port Replacement
  1. JBL Charge Micro USB / Aux Port Replacement, Disassembling JBL Charge Casing: step 1, image 1 of 3 JBL Charge Micro USB / Aux Port Replacement, Disassembling JBL Charge Casing: step 1, image 2 of 3 JBL Charge Micro USB / Aux Port Replacement, Disassembling JBL Charge Casing: step 1, image 3 of 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Micro USB / Aux Port Replacement: step 2, image 1 of 2 JBL Charge Micro USB / Aux Port Replacement: step 2, image 2 of 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Micro USB / Aux Port Replacement: step 3, image 1 of 2 JBL Charge Micro USB / Aux Port Replacement: step 3, image 2 of 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Micro USB / Aux Port Replacement: step 4, image 1 of 2 JBL Charge Micro USB / Aux Port Replacement: step 4, image 2 of 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Micro USB / Aux Port Replacement: step 5, image 1 of 2 JBL Charge Micro USB / Aux Port Replacement: step 5, image 2 of 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Micro USB / Aux Port Replacement: step 6, image 1 of 2 JBL Charge Micro USB / Aux Port Replacement: step 6, image 2 of 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Micro USB / Aux Port Replacement: step 7, image 1 of 2 JBL Charge Micro USB / Aux Port Replacement: step 7, image 2 of 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Micro USB / Aux Port Replacement, Battery: step 8, image 1 of 1
    • Turn your attention to the back casing removed in Step 7.
  9. JBL Charge Micro USB / Aux Port Replacement: step 9, image 1 of 1
    • Using a razor blade, remove the glue holding the battery cable in place.
    • Use multiple vertical cuts to remove pieces of the glue.
    • Be careful not to cut the battery cables.
  10. JBL Charge Micro USB / Aux Port Replacement: step 10, image 1 of 1
    • Remove the foam surrounding the battery cable.
  11. JBL Charge Micro USB / Aux Port Replacement: step 11, image 1 of 1
    • To remove the battery, pull the battery cable through the hole.
    • This entire white piece needs to be replaced (if replacing the aux/usb port).
  12. JBL Charge Micro USB / Aux Port Replacement, Micro USB / Aux Port: step 12, image 1 of 2 JBL Charge Micro USB / Aux Port Replacement, Micro USB / Aux Port: step 12, image 2 of 2
    • Place the battery into the new white casing.
    • Reassemble the device by following the steps in reverse order.
14 other people completed this guide.
Alexander Castanares
870 Reputation
2 Guides authored
Cal Poly, Team 12-4, Lancaster Spring 2015 Member of Cal Poly, Team 12-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G4
2 Members
18 Guides authored
21 Comments
Hi. This is the problem my speaker is having, but all I need to know is where to buy the replacement back. That's certainly something you should have included in your guide.
trevormeyer - Reply
The purpose of a guide is to show how to fix the device, not obtain parts. I suggest eBay.
Joe Durand -
Joe Durand. Thank you for taking time out of your busy day to share such an enlightening comment.
Pete Hyde -
Yeah what was the point of this if people can't actually do it. BS
Gabriel Bohlmann - Reply
The point is to guide people on the replacement of parts, not obtaining parts. I suggest eBay.
Joe Durand -
Past 24 Hours: 10
Past 7 Days: 42
Past 30 Days: 215
All Time: 111,297
