JBL Charge Motherboard Replacement
  1. JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: step 1, image 1 of 3 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: step 1, image 2 of 3 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: step 1, image 3 of 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Motherboard Replacement: step 2, image 1 of 2 JBL Charge Motherboard Replacement: step 2, image 2 of 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Motherboard Replacement: step 3, image 1 of 2 JBL Charge Motherboard Replacement: step 3, image 2 of 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Motherboard Replacement: step 4, image 1 of 2 JBL Charge Motherboard Replacement: step 4, image 2 of 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Motherboard Replacement: step 5, image 1 of 2 JBL Charge Motherboard Replacement: step 5, image 2 of 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Motherboard Replacement: step 6, image 1 of 2 JBL Charge Motherboard Replacement: step 6, image 2 of 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Motherboard Replacement: step 7, image 1 of 2 JBL Charge Motherboard Replacement: step 7, image 2 of 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Motherboard Replacement: step 9, image 1 of 2 JBL Charge Motherboard Replacement: step 9, image 2 of 2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Motherboard Replacement: step 10, image 1 of 1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Motherboard Replacement: step 11, image 1 of 2 JBL Charge Motherboard Replacement: step 11, image 2 of 2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
7 other people completed this guide.
Jake Bertholf
366 Reputation
2 Guides authored
Cal Poly, Team 12-1, Lancaster Spring 2015 Member of Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 Members
11 Guides authored
15 Comments
Hello I have 3 jbl speakers I bought that work only if plugged to the wall and aux cable... other than that it doesn't work at all .. Bluetooth or even the buttons don't function
hector - Reply
had same issue. fixed it by reconnecting the cable that conncts LEDs/ buttons
nyancatsarecute -
i have the same problem
Denny Berroa - Reply
Hello, mine doesn't emit any sound, bluetooth is connected, buttons are working, could it be that some audio cable inside is disconnected?
giubo - Reply
hello can i ask if how many pins in the flex for power button i accidentally damage when i fixed it
djcriztorey - Reply
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 75
All Time: 30,203
