JBL Clip 2 Carabineer Mount Replacement
  1. JBL Clip 2 Carabineer Mount Replacement, Carabineer Mount: step 1, image 1 of 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Carabineer Mount Replacement: step 2, image 1 of 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Carabineer Mount Replacement: step 3, image 1 of 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Carabineer Mount Replacement: step 4, image 1 of 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Carabineer Mount Replacement: step 5, image 1 of 1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Carabineer Mount Replacement: step 6, image 1 of 1
    • Slightly move the motherboard to the side to reveal the sides of battery, carefully using the blue plastic opening tool, remove the battery from the speaker casing.
    • Be careful not to disconnect any soldered wires connected to the motherboard and speaker casing.
  7. JBL Clip 2 Carabineer Mount Replacement: step 7, image 1 of 1
    • There are two 3 mm T8 screws holding the carabineer in place, remove these two screws.
3 other people completed this guide.
Michael Hong
1,014 Reputation
5 Guides authored
UW Tacoma, Team 2-2, Rose Winter 2017 Member of UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Members
7 Guides authored
2 Comments
i want to find that part ,dou you have web link to by
breakdancesok - Reply
where can i find this piece please
Daniel - Reply
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 91
All Time: 8,949
