Introduction
This guide is to help you replace the motherboard in a JBL Clip 3 speaker.
If none of your devices will connect to your JBL Clip 3 speaker, the problem could be a faulty Bluetooth chip in the motherboard. Before using this guide, try connecting alternative devices to ensure that it is, in fact, the JBL Clip 3 that will not connect. Once you confirm that the problem is specifically with the JBL Clip speaker, use this guide to replace the motherboard.
Note: Before beginning, make sure to power off the JBL Clip 3, and disconnect it from any external power sources.
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Use a pair of tweezers to release the two cable connections from the motherboard.
