JBL Clip Plus Microphone Replacement
  1. JBL Clip Plus Microphone Replacement, Battery: step 1, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Microphone Replacement: step 2, image 1 of 1
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Microphone Replacement: step 3, image 1 of 1
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Microphone Replacement: step 4, image 1 of 1
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Microphone Replacement: step 5, image 1 of 1
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Microphone Replacement: step 6, image 1 of 1
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Microphone Replacement: step 7, image 1 of 1
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Microphone Replacement: step 8, image 1 of 1
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Microphone Replacement: step 9, image 1 of 1
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Microphone Replacement: step 10, image 1 of 1
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Microphone Replacement, Microphone: step 11, image 1 of 1
Noah Pauk
809 Reputation
3 Guides authored
IUPUI, Team 3-4, Baechle Spring 2016 Member of IUPUI, Team 3-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G4
4 Members
6 Guides authored
1 Guide Comment
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
Mic - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 32
All Time: 2,185
