JBL Flip 4 Controls Board Replacement
  1. JBL Flip 4 Controls Board Replacement, Controls Board: step 1, image 1 of 3 JBL Flip 4 Controls Board Replacement, Controls Board: step 1, image 2 of 3 JBL Flip 4 Controls Board Replacement, Controls Board: step 1, image 3 of 3
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Pull off the cover off with your thumbs.
  2. JBL Flip 4 Controls Board Replacement: step 2, image 1 of 3 JBL Flip 4 Controls Board Replacement: step 2, image 2 of 3 JBL Flip 4 Controls Board Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool under the clear rubber cover over the button control board.
    • Pry up the cover using the opening tool.
    • The cover is glued on so it will take some force to pry up.
  3. JBL Flip 4 Controls Board Replacement: step 3, image 1 of 2 JBL Flip 4 Controls Board Replacement: step 3, image 2 of 2
    • Pry up the button control board by inserting the metal spudger underneath both sides of the board.
    • Try not to damage the green control board while using the metal tools.
    • The control board is glued down as well, so you will need to use some force.
  4. JBL Flip 4 Controls Board Replacement: step 4, image 1 of 1
    • Once the board is partially unattached, pull it off using your hands.
20 other people completed this guide.
Philip Pang
1,255 Reputation
4 Guides authored
Cal Poly, Team S4-G3, White Fall 2018 Member of Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Members
36 Guides authored
7 Comments
Where can i buy ,control board for jbl flip 4?
Mihajlo - Reply
I would also be interested in buying a board (but the one at the top of the speaker, whichis holding the On and Off, as well as the JBL Connect button ). Thanks!
JPA - Reply
Does anyone at ifixit know where to get replacement boards?
EAN - 2/28/19
Eric - Reply
Id be interested in JBLmaking a minimally acceptable product
Mary Lea McTurnan - Reply
Where can I buy the ribbon cable?
Randl Manigsaca - Reply
Past 24 Hours: 13
Past 7 Days: 81
Past 30 Days: 376
All Time: 31,821
