JBL Flip 4 Front Active Speaker Replacement
  1. JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: step 1, image 1 of 3 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: step 1, image 2 of 3 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: step 1, image 3 of 3
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, it will make a snapping sound.
    • Pull off the cover with your thumbs.
  2. JBL Flip 4 Front Active Speaker Replacement: step 2, image 1 of 1
    • Remove all four 10 mm JIS #1 screws around the damaged front active speaker.
    • The speakers are strong magnets. Keep metal tools or other magnetic objects away from the driver.
  3. JBL Flip 4 Front Active Speaker Replacement: step 3, image 1 of 3 JBL Flip 4 Front Active Speaker Replacement: step 3, image 2 of 3 JBL Flip 4 Front Active Speaker Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool under the unscrewed front active speaker.
    • Pry off the front active speaker with the opening tool.
    • Do not yank the front active speaker out. It is connected to wires within the device.
  4. JBL Flip 4 Front Active Speaker Replacement: step 4, image 1 of 1
    • Cut the red, white, and black wires connected to the speaker using wire cutters.
    • You will need to re-solder these wires when installing the new speaker.
14 other people completed this guide.
Ryan Whitlock
2,138 Reputation
1 Guide authored
Cal Poly, Team S4-G3, White Fall 2018 Member of Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Members
36 Guides authored
16 Comments
And where can you find the replacement part? I cannot find a replacement speaker on the internet…
Sven Meirsman - Reply
Exactly, what is the part number for the internal speaker?
Dan The Menace Brenes - Reply
The part number is: psp00018001
Johankat -
If the magnet comes loose from the speaker how do you get it back on?
Andrew Sumahit - Reply
Replace the entire speaker.
Magnet realignment is crucial for the speaker to perform properly.
Johankat -
Past 24 Hours: 17
Past 7 Days: 99
Past 30 Days: 425
All Time: 35,311
