JBL Flip 4 Shell Replacement
  1. JBL Flip 4 Shell Replacement, Shell: step 1, image 1 of 3 JBL Flip 4 Shell Replacement, Shell: step 1, image 2 of 3 JBL Flip 4 Shell Replacement, Shell: step 1, image 3 of 3
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 Shell Replacement: step 2, image 1 of 3 JBL Flip 4 Shell Replacement: step 2, image 2 of 3 JBL Flip 4 Shell Replacement: step 2, image 3 of 3
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
9 other people completed this guide.
Philip Pang
1,389 Reputation
4 Guides authored
Cal Poly, Team S4-G3, White Fall 2018 Member of Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Members
37 Guides authored
2 Guide Comments
教程不难, 难的是哪里可以买到配件。
Toki - Reply
Buenas tarde busco remplazo de carcasa frontal del jbl flit 4
william marin lopez - Reply
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 316
All Time: 16,947
