JBL Flip disassembly
  1. JBL Flip disassembly, JBL Flip disassembly: step 1, image 1 of 3 JBL Flip disassembly, JBL Flip disassembly: step 1, image 2 of 3 JBL Flip disassembly, JBL Flip disassembly: step 1, image 3 of 3
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
  2. JBL Flip disassembly: step 2, image 1 of 3 JBL Flip disassembly: step 2, image 2 of 3 JBL Flip disassembly: step 2, image 3 of 3
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
  3. JBL Flip disassembly: step 3, image 1 of 3 JBL Flip disassembly: step 3, image 2 of 3 JBL Flip disassembly: step 3, image 3 of 3
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
  4. JBL Flip disassembly: step 4, image 1 of 1
    • Remove last white back plate to expose the back of the speaker cover.
  5. JBL Flip disassembly: step 5, image 1 of 3 JBL Flip disassembly: step 5, image 2 of 3 JBL Flip disassembly: step 5, image 3 of 3
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
  6. JBL Flip disassembly: step 6, image 1 of 3 JBL Flip disassembly: step 6, image 2 of 3 JBL Flip disassembly: step 6, image 3 of 3
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
12 other people completed this guide.
Dillon
1,580 Reputation
5 Guides authored
4 Guide Comments
How do i take apart jbl flip 3
Ricky Tomas - Reply
My jbl flip 3 Bluetooth button does not function.How do I fix the problem?
Francis
fwathika - Reply
The charging PCB on my Flip3 is damaged and needs to be replaced. Any chance of purchasing the charging/interface module, fully populated?
I live in South Africa, and cannot find it here!
Paul M
Paul Moulang - Reply
The charging PCB on my JBL Flip3 is also damaged and needs to be replaced. Any chance of purchasing the charging/interface module?
I live in Pune - Maharashtra in India and cannot find a good reliable service station for JBL speakers here!
Suresh Karve
Suresh Karve - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 72
All Time: 23,001
