JBL L26 Speaker Replacement
  1. JBL L26 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Remove the four 6.4 mm Phillips #2 screws from the front of the speaker.
  2. JBL L26 Speaker Replacement: step 2, image 1 of 1
    • Pull the speaker out of the frame and lay it onto the side.
  3. JBL L26 Speaker Replacement: step 3, image 1 of 1
    • Unlatch the green wire by pulling on the terminal connector and not the wire.
  4. JBL L26 Speaker Replacement: step 4, image 1 of 2 JBL L26 Speaker Replacement: step 4, image 2 of 2
    • Use a small prying tool to pry the terminal connector off of the tap.
    • After you unlatched both edges, pull the black wire out.
  5. JBL L26 Speaker Replacement: step 5, image 1 of 1
    • Get your replacement speaker and connect the green wire by pushing the terminal connector onto the tap.
  6. JBL L26 Speaker Replacement: step 6, image 1 of 2 JBL L26 Speaker Replacement: step 6, image 2 of 2
    • Connect the black wire by attaching the terminal connector onto the tap.
    • Use a clamping tool to clip the edges toward the tap.
    • Be careful not to clamp too hard so you don't damage the tap.
  7. JBL L26 Speaker Replacement: step 7, image 1 of 1
    • Place the new speaker onto the frame and screw the four 6.4 mm Phillips #2 screws back in.
Nathnael Dubale
269 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,081
