JBL Link 10 battery Replacement
    • jbl link 10 battery replacement
    • peel the bottom cover off
    • be careful not to damage the charging port
    • remove the screws that are hidden underneath the base
    • carefully remove the charging port
    • be careful of the cables that are still connected to the motherboard.
    • use a flat screwdriver or spudger to carefully pry up the plastic
    • carefully unplug the old battery from the 6 pin connector on the motherboard
    • -be extremely careful not to damage the connector.
    • carefully take the old battery out.
    • this should be easy if you are doing it correctly.
776831
1,095 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,541
