JBL On Stage II 30-Pin Connector Replacement
  1. JBL On Stage II 30-Pin Connector Replacement, Cracking the Case: step 1, image 1 of 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II 30-Pin Connector Replacement: step 2, image 1 of 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II 30-Pin Connector Replacement: step 3, image 1 of 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II 30-Pin Connector Replacement: step 4, image 1 of 2 JBL On Stage II 30-Pin Connector Replacement: step 4, image 2 of 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II 30-Pin Connector Replacement: step 5, image 1 of 3 JBL On Stage II 30-Pin Connector Replacement: step 5, image 2 of 3 JBL On Stage II 30-Pin Connector Replacement: step 5, image 3 of 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II 30-Pin Connector Replacement: step 6, image 1 of 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II 30-Pin Connector Replacement: step 7, image 1 of 2 JBL On Stage II 30-Pin Connector Replacement: step 7, image 2 of 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II 30-Pin Connector Replacement, 30-Pin Connector Replacement: step 8, image 1 of 1
    • Apply heat with a heatgun on a low setting to the area around the 30-pin connector until you can easily pry it out by the seam surrounding it (about 10 minutes).
  9. JBL On Stage II 30-Pin Connector Replacement: step 9, image 1 of 1
    • Use a metal spudger to pry out the plastic surrounding the 30-pin connector.
  10. JBL On Stage II 30-Pin Connector Replacement: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to wiggle out the 30-pin connector.
Janessa D Cabrera
514 Reputation
4 Guides authored
Cal Poly, Team 9-28, Maness Winter 2014 Member of Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Members
7 Guides authored
2 Comments
and how you get a new one of the 30 pin connector?
bini barazany - Reply
Yes, where can we buy a new one of the 30 pin connector?
Jimbo - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 4,481
