Introduction
If your JBL 2 speaker isn't working correctly or delivering the high-quality sounds you expect, you may need to replace the battery. Replacing the battery can breathe new life into your device.
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
6 other people completed this guide.
