Introduction
There are four speakers located on the base of the JBL Pulse 3 under the speaker grill.
Lay the JBL Pulse 3 on its side as shown in the picture.
Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
Pull the LED light display off of the JBL Pulse 3 base.
Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
Note: To finish replacing the speaker, you must solder both wires back on to the new speaker.
