JBL Pulse LED Light Replacement
  1. JBL Pulse LED Light Replacement, Button Board: step 1, image 1 of 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse LED Light Replacement: step 2, image 1 of 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse LED Light Replacement: step 3, image 1 of 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse LED Light Replacement: step 4, image 1 of 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse LED Light Replacement: step 5, image 1 of 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse LED Light Replacement, Outer Casing: step 6, image 1 of 3 JBL Pulse LED Light Replacement, Outer Casing: step 6, image 2 of 3 JBL Pulse LED Light Replacement, Outer Casing: step 6, image 3 of 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: step 7, image 1 of 2 JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: step 7, image 2 of 2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse LED Light Replacement, LED Light: step 8, image 1 of 1
    • Pry off LED light panel using a metal spudger.
2 other people completed this guide.
Maxwell Busenbarrick
1,377 Reputation
7 Guides authored
USF Tampa, Team 18-6, Blackwell Fall 2016 Member of USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Members
13 Guides authored
1 Guide Comment
Were do I buy a Replacement led strip?
Jalen6988 - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 3,618
