JBL Pulse Motherboard Replacement
  1. JBL Pulse Motherboard Replacement, Button Board: step 1, image 1 of 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Motherboard Replacement: step 2, image 1 of 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Motherboard Replacement: step 3, image 1 of 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Motherboard Replacement: step 4, image 1 of 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Motherboard Replacement: step 5, image 1 of 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Motherboard Replacement, Outer Casing: step 6, image 1 of 3 JBL Pulse Motherboard Replacement, Outer Casing: step 6, image 2 of 3 JBL Pulse Motherboard Replacement, Outer Casing: step 6, image 3 of 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: step 7, image 1 of 2 JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: step 7, image 2 of 2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Motherboard Replacement, JBL Pulse Disassembly: step 8, image 1 of 1
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
  9. JBL Pulse Motherboard Replacement: step 9, image 1 of 3 JBL Pulse Motherboard Replacement: step 9, image 2 of 3 JBL Pulse Motherboard Replacement: step 9, image 3 of 3
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Motherboard Replacement: step 10, image 1 of 2 JBL Pulse Motherboard Replacement: step 10, image 2 of 2
    • Remove cables by pulling firmly.
  11. JBL Pulse Motherboard Replacement, Motherboard: step 11, image 1 of 1
    • Once all of the cables are removed, grip the motherboard and slide it out.
3 other people completed this guide.
Maxwell Busenbarrick
1,377 Reputation
7 Guides authored
USF Tampa, Team 18-6, Blackwell Fall 2016 Member of USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Members
13 Guides authored
3 Guide Comments
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - Reply
my usb port is damaged. Do I have to replace the whole motherboarD?
dinosdabi - Reply
Hey I need JBL pulse motherboard Where can I buy. Please help
kashyapvikas228vk1070301 - Reply
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 42
All Time: 9,860
