JBL Pulse Outer Casing Replacement
  1. JBL Pulse Outer Casing Replacement, Button Board: step 1, image 1 of 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Outer Casing Replacement: step 2, image 1 of 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Outer Casing Replacement: step 3, image 1 of 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Outer Casing Replacement: step 4, image 1 of 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Outer Casing Replacement: step 5, image 1 of 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Outer Casing Replacement, Outer Casing: step 6, image 1 of 3 JBL Pulse Outer Casing Replacement, Outer Casing: step 6, image 2 of 3 JBL Pulse Outer Casing Replacement, Outer Casing: step 6, image 3 of 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
2 other people completed this guide.
Maxwell Busenbarrick
1,377 Reputation
7 Guides authored
USF Tampa, Team 18-6, Blackwell Fall 2016 Member of USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 2,751
