JBL Xtreme 2 Speaker Replacement
  1. JBL Xtreme 2 Speaker Replacement, Speaker: step 1, image 1 of 2 JBL Xtreme 2 Speaker Replacement, Speaker: step 1, image 2 of 2
    • Use a spudger or other prying tool to gently pry open the middle section of the speaker.
  2. JBL Xtreme 2 Speaker Replacement: step 2, image 1 of 2 JBL Xtreme 2 Speaker Replacement: step 2, image 2 of 2
    • To open the case, open the front side gently rotating along the hinge.
  3. JBL Xtreme 2 Speaker Replacement: step 3, image 1 of 1
    • Once you have the speakers exposed like in the image, at the bottom part you will snap open the back end piece of the grill still attached.
  4. JBL Xtreme 2 Speaker Replacement: step 4, image 1 of 3 JBL Xtreme 2 Speaker Replacement: step 4, image 2 of 3 JBL Xtreme 2 Speaker Replacement: step 4, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the four 12.9 mm screws securing the faulty speaker.
    • Once you remove the screws, the speaker will be loose and you will be able to move it around easily.
  5. JBL Xtreme 2 Speaker Replacement: step 5, image 1 of 3 JBL Xtreme 2 Speaker Replacement: step 5, image 2 of 3 JBL Xtreme 2 Speaker Replacement: step 5, image 3 of 3
    • Lift the speaker out of its housing and you will see two cables connecting the speaker. Pull the speaker towards you and each of the cable connectors away from you.
    • Do the same for both cables.
2 other people completed this guide.
charlymoron
169 Reputation
1 Guide authored
One Comment
Jep u open it wrong way. I broken My speaker Plastic attachment so i need extra work whit wrong opening way. I can sent u a some pic whit this.
Bender - Reply
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 118
All Time: 2,316
