JBL Xtreme 3 Battery Replacement
  1. JBL Xtreme 3 Battery Replacement, Battery: step 1, image 1 of 1
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: step 2, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: step 3, image 1 of 2 JBL Xtreme 3 Battery Replacement: step 3, image 2 of 2
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
  4. JBL Xtreme 3 Battery Replacement: step 4, image 1 of 2 JBL Xtreme 3 Battery Replacement: step 4, image 2 of 2
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: step 5, image 1 of 2 JBL Xtreme 3 Battery Replacement: step 5, image 2 of 2
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: step 6, image 1 of 3 JBL Xtreme 3 Battery Replacement: step 6, image 2 of 3 JBL Xtreme 3 Battery Replacement: step 6, image 3 of 3
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
5 other people completed this guide.
Maria
472 Reputation
3 Guides authored
One Comment
Great guide! Thank you!
dam damo - Reply
Past 24 Hours: 6
Past 7 Days: 56
Past 30 Days: 215
All Time: 2,946
