JBL Xtreme 3 Hooks Replacement
  1. JBL Xtreme 3 Hooks Replacement, Exterior Speaker Shell Cover: step 1, image 1 of 1
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Hooks Replacement: step 2, image 1 of 1
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Hooks Replacement: step 3, image 1 of 2 JBL Xtreme 3 Hooks Replacement: step 3, image 2 of 2
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
  4. JBL Xtreme 3 Hooks Replacement, Hooks: step 4, image 1 of 2 JBL Xtreme 3 Hooks Replacement, Hooks: step 4, image 2 of 2
    • Use a #1 Phillip's screwdriver to remove the 2 screws on the hook.
    • Repeat for the second hook, if needed.
    • Replace the hook, or both if needed.
Maria
472 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 292
