JBL Xtreme 3 LED Light Replacement
  1. JBL Xtreme 3 LED Light Replacement, Exterior Speaker Shell Cover: step 1, image 1 of 1
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 LED Light Replacement: step 2, image 1 of 1
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 LED Light Replacement: step 3, image 1 of 2 JBL Xtreme 3 LED Light Replacement: step 3, image 2 of 2
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
  4. JBL Xtreme 3 LED Light Replacement, LED Light: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to remove 4 screws from the lighting plate.
  5. JBL Xtreme 3 LED Light Replacement: step 5, image 1 of 1
    • Use a spudger to remove the plate and silicone matting underneath.
  6. JBL Xtreme 3 LED Light Replacement: step 6, image 1 of 1
    • Use a spudger to remove the lightboard.
    • Disconnect the cable. Gently pinch and pull on the white tab until the board and cable disconnect.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 358
