JBL Xtreme Bass Radiator Replacement
  1. JBL Xtreme Bass Radiator Replacement, Cover: step 1, image 1 of 1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Bass Radiator Replacement: step 2, image 1 of 2 JBL Xtreme Bass Radiator Replacement: step 2, image 2 of 2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Bass Radiator Replacement: step 3, image 1 of 2 JBL Xtreme Bass Radiator Replacement: step 3, image 2 of 2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Bass Radiator Replacement, Bass Radiator: step 4, image 1 of 3 JBL Xtreme Bass Radiator Replacement, Bass Radiator: step 4, image 2 of 3 JBL Xtreme Bass Radiator Replacement, Bass Radiator: step 4, image 3 of 3
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Bass Radiator Replacement: step 5, image 1 of 3 JBL Xtreme Bass Radiator Replacement: step 5, image 2 of 3 JBL Xtreme Bass Radiator Replacement: step 5, image 3 of 3
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
12 other people completed this guide.
Benny Huynh
1,953 Reputation
4 Guides authored
USF Tampa, Team 1-1, Sullivan Spring 2017 Member of USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 Members
27 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 96
All Time: 20,758
