JBL Xtreme Cover Disassembly
  1. JBL Xtreme Cover Disassembly, Cover: step 1, image 1 of 1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Cover Disassembly: step 2, image 1 of 2 JBL Xtreme Cover Disassembly: step 2, image 2 of 2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Cover Disassembly: step 3, image 1 of 2 JBL Xtreme Cover Disassembly: step 3, image 2 of 2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
14 other people completed this guide.
Benny Huynh
1,953 Reputation
4 Guides authored
USF Tampa, Team 1-1, Sullivan Spring 2017 Member of USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 Members
27 Guides authored
5 Comments
Can you fix my cover on speaker
c_pg08 - Reply
where can I find a new cover for xtreme 2, if possible in black?
vale0501 - Reply
If you find a place to buy a cover let me know
abjayaman -
you forgot about 2 screws
Enescu Catalin - Reply
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
megakacper11 - Reply
Past 24 Hours: 13
Past 7 Days: 54
Past 30 Days: 207
All Time: 31,003
