JD Razor 2000 Front Wheel Replacement
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: step 1, image 1 of 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: step 1, image 2 of 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: step 1, image 3 of 3
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: step 2, image 1 of 1
    • Grip the bottom of the wheel and gently slide it out.
Kaylan Naicker
255 Reputation
2 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,140
