JD Razor 2000 Quick-Release Lever Replacement
  1. JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: step 1, image 1 of 2 JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: step 1, image 2 of 2
    • Unlock the quick-release lever by turning the lever from a tightened position.
  2. JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: step 2, image 1 of 3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: step 2, image 2 of 3 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: step 2, image 3 of 3
    • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
    • Be sure to fasten the opposite side of the screw before unscrewing.
    • Remove the screw and note the order of the parts for reassembly.
  3. JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: step 3, image 1 of 3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: step 3, image 2 of 3 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: step 3, image 3 of 3
    • Turn the quick-release lever over to reveal an 8mm screw.
    • Use the Phillips #2 screw driver to remove the screw.
    • After removing the screw, the circular latch will be detachable.
Shane
384 Reputation
3 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 2,543
