JD Razor 2000 Wheelie Bar Replacement
  1. JD Razor 2000 Wheelie Bar Replacement, Unscrewing the Axle Bolt: step 1, image 1 of 2 JD Razor 2000 Wheelie Bar Replacement, Unscrewing the Axle Bolt: step 1, image 2 of 2
    • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
    • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
  2. JD Razor 2000 Wheelie Bar Replacement, Removing the Bolt and Bearing: step 2, image 1 of 2 JD Razor 2000 Wheelie Bar Replacement, Removing the Bolt and Bearing: step 2, image 2 of 2
    • Remove the bolt from the right side and the bearing from the left.
  3. JD Razor 2000 Wheelie Bar Replacement, Removing the Wheel: step 3, image 1 of 1
    • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
  4. JD Razor 2000 Wheelie Bar Replacement, Pulling Out the Wheelie Bar: step 4, image 1 of 1
    • Pull the wheelie bar away from the deck of the scooter.
If you need more assistance, visit our troubleshooting guide here.
Shane
384 Reputation
3 Guides authored
Cal Poly, Team 4-46, Amido Fall 2014 Member of Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,357
