JVC GR-D72U Lateral Function Port Panel Replacement
  1. JVC GR-D72U Lateral Function Port Panel Replacement, Battery: step 1, image 1 of 2 JVC GR-D72U Lateral Function Port Panel Replacement, Battery: step 1, image 2 of 2
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Lateral Function Port Panel Replacement: step 2, image 1 of 1
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: step 3, image 1 of 3 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: step 3, image 2 of 3 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: step 3, image 3 of 3
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Lateral Function Port Panel Replacement: step 4, image 1 of 1
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Lateral Function Port Panel Replacement: step 5, image 1 of 1
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Lateral Function Port Panel Replacement: step 6, image 1 of 1
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Lateral Function Port Panel Replacement: step 7, image 1 of 1
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Lateral Function Port Panel Replacement: step 8, image 1 of 1
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Lateral Function Port Panel Replacement: step 9, image 1 of 3 JVC GR-D72U Lateral Function Port Panel Replacement: step 9, image 2 of 3 JVC GR-D72U Lateral Function Port Panel Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
2 other people completed this guide.
Joshua Hatcherian
194 Reputation
1 Guide authored
USF Tampa, Team S2-G2, Nance Fall 2017 Member of USF Tampa, Team S2-G2, Nance Fall 2017
USFT-NANCE-F17S2G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 693
